[Qgis-user] Possible Postgis view opening bug
pcreso at pcreso.com
Sun Feb 8 16:31:09 PST 2009
I'm trying to open a PostGIS view in QGIS, & get told there is no suitable key. I don't want to file a bug if it is my mistake, so figured I'd ask if anyone else has a similar problem or can point out where I've gone wrong.
However, I believe there is a suitable key, details below:
SELECT DISTINCT o.id AS obs_id,
o.trip_code,
o.station_no,
o."timestamp",
o.obs_id AS obs_type_id,
t.category,
t.descr,
o.version,
o."comment",
s.speed,
s.course,
s.heading,
s.depth,
s.main_substrate,
s.geom
FROM obs o,
obs_type t,
spline s
WHERE o.obs_id = t.obs_id
AND o."timestamp" = s."timestamp";
The o.id (obs_id) column is a primary key in obs, so is guaranteed unique in the underlying table. S.timestamp has a unique index on it in the underlying table, as does obs_type.id.
I believe QGIS uses the following SQL to test for uniqeness in a column, which returns true in this case:
select count(distinct obs_id) = count(obs_id) from v_obs_pos ;
?column?
t
(1 row)
My version of the same test gives 0 duplicates in the underlying table & the view:
select count(*) from (select obs_id from v_obs_pos group by obs_id having count(*) > 1 limit 1) as foo;
count
0
(1 row)
ofop=# select count(*) from (select id from obs group by id having count(*) > 1 limit 1) as foo;
count
0
(1 row)
But QGIS gives an error msg:
"Note: 'id' initially appeared suitable but does not contain unique data, so is not suitable."
Does anyone have any ideas?
Thanks,
Brent Wood
