[Qgis-user] watershed creation
Ralf Suhr
gisbox at web.de
Tue Feb 17 11:00:07 PST 2009
Did you set the "area of interest" with g.region=dem?
Am Montag, 16. Februar 2009 23:34:02 schrieb G. Allegri:
> I usually use r.watershed directly from GRASS and I choose the output
> I desire (basin, drainage, stream segments, etc.), and the command
> looks something like:
> r.watershed elevation=dem drainage=out_drain basin=out_basin
> to get the raster of basins with unique values (basin) and the
> drainage network (drainage).
> Which QGIS version are you using? What OS? How big is your dem? What
> resolution?
> giovanni
> 2009/2/16 ambrish dhaka <ambijat at hotmail.com>:
> > Hello all,
> > I found that the raster > hydrology..> watershed tool does not create the
> > desired image.
> > I used three things...1) the dem raster as source, 2) threshold value of
> > 1000 and 3) output name as accu1.
> > Is there anything else left?
> > Why it is not producing, and how can I create basins?
> > Regards,
> > Ambrish Dhaka
> > ________________________________
> > Voice your opinion on the burning issues of the day. Discuss, debate with
> > the world. Logon to message boards on MSN. Try it!
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Ralf
