[Qgis-user] QGIS 1.0.0 incompatybile library version
    massimo di stefano
    massimodisasha at yahoo.it
    Fri Jan  2 03:48:52 PST 2009
Hi All,
i had the same problem on osx.
using the last svn (version 1.1.0)
at the spalsh screen, under the step "restore plugins"
it freeze and open a window message
>> incompatybile library version module
it happens if i try to compile qgis from its old svn directory (1.0.0)
and done an  "svn up" to update the code.
to solve it i downloaded a new fresh svn and compiling it All woks fine.
epifanio
Il giorno 02/gen/09, alle ore 09:20, qgis-user-request at lists.osgeo.org
ha scritto:
> Hi
> Can you check if any old versions of QGIS exist on your system and
> remove them if present - QGIS 1.x does not work well with older QGIS
> libs present on your system. I'm not sure if that is indeed what is
> causing your problem, but its the first place you should look...
> Regards
> Tim
> On Wed, 2008-12-31 at 16:31 +0100, Jarek Jasiewicz wrote:
>> Hi
>> This message appears during starting qgis (Latest complilation from
>> svn
>> head),
>> probably during  loading plugin-is, in message window titled in
>> polish:
>> "Nieobsługiwany błąd krytyczny":
>> this polish message can be translated as "not supported critical
>> error",
>> I cannot say what is its source
>> next program stop to work. Removing qgis both from /usr/local and
>> ~/.qgis directories and successive compilation and do not solve the
>> problem
>> ldd /usr/local/binqgis load all libraries withouth error
>> I cannot say nothing more about possible reason of that error. I use
>> Ubuntu 8.04 with laetest version of Qt and grass 6.4 also just
>> complied
>> from svn head
>> Jarek
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
