[Qgis-user] error message
Chris h
chris123 at magma.ca
Fri Jan 2 11:13:20 PST 2009
Greets:
Was wondering if someone can decifer the following error message please:
Warning: QgsCoordinateReferenceSystem::getRecord failed : select * from
tbl_srs where parameters='+proj=longlat +a=6371200 +b=6371200 +no_defs'
Warning: QgsCoordinateReferenceSystem::findMatchingProj will only work if prj
acr ellipsoid acr and proj4string are set!...
Critical: QgsCoordinateReferenceSystem::createFromWkt -- theWkt is
uninitialised, operation failed
---------------------------------------------------e0f----------------------------
How this comes about is as follows:
1. download an NOAA grib file
2. gdal-info shows the file is not corrupt and properly configured
2. gdal_translate creates a sample.tif and sample.aux.xml file holding the
meta data
3. loading the sample.tif as a raster into qgis produces the above generated
error.
Is there any way I can correct for this?
gdal = 1.6.0beta2, released 2008/11/12
gqis = 1.0 Kore
os = ubuntu 8.04
Best regards and thanks
/ch
