[Qgis-user] Re: GRASS raster reading to QGIS 1.0.0 Kore
Martin Dobias wonder.sk at gmail.com
Sun Jan 4 09:03:13 PST 2009
2009/1/4 Patrick Giraudoux <patrick.giraudoux at univ-fcomte.fr>:
> Seems that I can narrow the question now. Actually, QGIS Kore reads GRASS
> maps well except when the maps  have been created from raster ramp color
> have been optimized with i.landsat.rgb. For example in GRASS:
> r.composite r=etm7 g=etm5 b=etm2 out=south752brut
> makes a map 'south752brut' which is well read within QGIS
> Now if I do:
> i.landsat.rgb r=etm7 g=etm5 b=etm2
> r.composite r=etm7 g=etm5 b=etm2 out=south752opt
> it makes a map 'south752opt' which is extremly long to read (several
> minutes), and when read makes change (displacement, zoom, etc...) extremely
> long to be displayed at a speed that prevent any work
> However, 'south752opt' and 'south752brut' are quick/normally displayed both
> at the same speed when on work within GRASS (e.g. d.rast south752opt)
> Any hint ?
Hi Patrick,
we're using GDAL library to access GRASS rasters, so the problem may
be there. I would suggest you to try reading the raster in some other
GDAL-based software [1] to see whether it also suffers slow
performance. If so, file a bug for GDAL, if the problem happens only
in QGIS file a ticket for QGIS with details.
Martin
[1] https://trac.osgeo.org/gdal/wiki/SoftwareUsingGdal
