[Qgis-user] Projection
Albin Blaschka albin.blaschka at gmail.com
Wed Jan 7 07:18:40 PST 2009
Werner Macho schrieb:
> So were there any discussion about reading .prj files i missed or can
> someone (hopefully a developer) provide me some information why QGIS is
> not reading .prj infos?
> At least a small button with "read prj file" to give the right .prj file
> for reading raster or vector files would even be more helpfull (and at
> least easier) than defining the projection by myself.
Hello,
I am no developer, but I once had the problem with a .prj - File on
Linux that ist was there, but not readable: don't ask me why - IIRC it
was because of some weird copying back and forth - and I was not the
owner of the file... So I had no rights to read the file...
A second possibility would be that the .prj File is corrupted, but then
it should not work on windows either...or maybe different coding of line
-endings (CR/LF... but I do not know if this could be an issue with a
.prj-file...)
Good Luck!
Albin
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info * www.thinkanimal.info *
| - It's hard to live in the mountains, hard but not hopeless!
