[Qgis-user] Python error
Bernardo Rossi Doria berrossi at tin.it
Wed Jan 14 11:49:02 PST 2009
thank you
I proceeded as you suggested
now no problems
bernardo
Il giorno 14/gen/09, alle ore 19:06, John C. Tull ha scritto:
> On Jan 14, 2009, at 9:55 AM, Bernardo Rossi Doria wrote:
>> hello all
>> downloaded and installed qgis 1.0 osx  after I deleted previous
>> version on macbook pro
>> When I open the app  a Python error comes out with this description.
>> Couldn't load plugin "newlayer" from
>> ['/Applications/qgis-1.0.0/qgis1.0.0.app/Contents/MacOS/share/qgis/
>> python', '/Users/bernardo/.qgis//python/plugins', '/Applications/
>> qgis-1.0.0/qgis1.0.0.app/Contents/MacOS/share/qgis/python/plugins',
>> '/Library/Python/2.5/site-packages/GDAL-1.5.2-py2.5-macosx-10.5-
>> i386.egg', '/System/Library/Frameworks/Python.framework/Versions/
>> 2.5/lib/python25.zip', '/System/Library/Frameworks/Python.framework/
>> Versions/2.5/lib/python2.5', '/System/Library/Frameworks/
>> Python.framework/Versions/2.5/lib/python2.5/plat-darwin', '/System/
>> Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-
>> mac', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/
>> python2.5/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/
>> Python.framework/Versions/2.5/Extras/lib/python', '/System/Library/
>> Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk', '/
>> python2.5/lib-dynload', '/Library/Python/2.5/site-packages', '/
>> Users/bernardo/.qgis/python/plugins/fTools_preview2/tools']
>> Traceback (most recent call last):
>>  File "", line 2, in
>>  File "/Users/bernardo/.qgis//python/plugins/newlayer/__init__.py",
>> line 2, in
>>    from newlayer import NewLayer
>>  File "/Users/bernardo/.qgis//python/plugins/newlayer/newlayer.py",
>> line 5, in
>>    import psycopg
>> ImportError: No module named psycopg
>> Versione Python:
>> 2.5.1 (r251:54863, Jan 17 2008, 19:35:17)
>> [GCC 4.0.1 (Apple Inc. build 5465)]
>> If I click OK the application freezes
>> So I deleted in  Application /contents       the PyQt4 folder
>> content and then it says : "Impossibile caricare PyQt4.
>> Il supporto Python verrĂ  disabilitato."  but opens and  works fine
>> with other plugins.
>> What is wrong with PyQt4?
> I don't think anything is wrong with PyQt4. Instead of deleting
> necessary items from the application bundle, you need to delete your
> incompatible plugin. From the terminal do:
> rm -r /Users/bernardo/.qgis/python/plugins/newlayer
> That will take care of the offending plugin. You may have others, in
> which case, doing:
> is probably preferable (start with a clean slate for the new API in
> 1.0.0).
> You also need to reinstall your qgis application because you need
> everything inside the application bundle. Deleting things from there
> will break it every time.
> Regards,
> John
