[Qgis-user] Graticules
Agustin Lobo
Agustin.Lobo at ija.csic.es
Tue Jan 27 02:15:04 PST 2009
Not sure if Tools/Sampling Tool is the appropriate place for the user
to find this tool, though.
Agus
Tim Sutton wrote:
> Hi
> I suggest we remove my original C++ graticule plugin from svn since
> Carson's tools collection now replicates this.
> Any objections?
> Regards
> Tim
> On Tue, 2009-01-27 at 08:56 +0100, Agustin Lobo wrote:
>> Carson,
>> This is actually almost perfect and I do confirm that works
>> in the projection being defined for the project.
>> The only improvement would be that once you select "Input Boundary
>> Layer" you should get the actual values written in the X,Y fields
>> of "Input Coordinates". In this way, the user could then select "Input
>> coordinates" to slightly modify the values (you normally want
>> the grid at rounded positions).
>> Thanks a lot
>> Agus
>> Carson Farmer wrote:
>>> Hi Augus
>>>> Agustin Lobo wrote:
>>>>>> Could be considered that the graticule creator work in projected
>>>>>> coordinates? It's hard making a UTM graticule by entering geographic
>>>>>> values. Also, it would useful if the default values for the extent
>>>>>> could be those of the displayed region and/or those of the extent of
>>>>>> a given layer.
>>> You could probably do this with the vector grid function in fTools as
>>> well...
>>> Though now that I think of it... you might be limited to geographic
>>> coordinates here as well... but you could probably get around this by
>>> specifying UTM coordinates, and defining the projection to be UTM after
>>> the grid is created... I'm not sure though...
>>> C
>>>> Tim Sutton wrote:
>>>>> On my last round of edits to the graticule plugin, I put in
>>>>> the groundwork for this. I will add it to the feature plan for 1.1
>>>> Hi,
>>>> if you use the GRASS plugin you can theoretically do such things with the
>>>> v.mkgrid module.
>>>> perhaps src/plugins/grass/modules/v.mkgrid.region.qgm needs to be updated
>>>> to give access to more module options:
>>>> http://grass.osgeo.org/grass64/manuals/html64_user/v.mkgrid.html
>>>> maybe as a new v.mkgrid.coor.qgm ?
>>>> Hamish
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
