[Qgis-user] Graticules
Carson Farmer
carson.farmer at gmail.com
Tue Jan 27 15:49:22 PST 2009
Hi all,
>>> This is actually almost perfect and I do confirm that works
>>> in the projection being defined for the project.
>>> The only improvement would be that once you select "Input Boundary
>>> Layer" you should get the actual values written in the X,Y fields
>>> of "Input Coordinates". In this way, the user could then select "Input
>>> coordinates" to slightly modify the values (you normally want
>>> the grid at rounded positions).
This has been added, along with the bug fix for using the manually
entered extents (the whole setup has been changed a bit). These changes
are now in svn rev10035.
Hope that solves your problems...
Carson
