[Qgis-user] print composer scalebar help?
    Carson Farmer
    carson.farmer at gmail.com
    Fri Jan 30 09:12:11 PST 2009
Hi Ross,
> The print composer has me kind of stumped...
> What I'd like is a simple scale bar to indicate how long a mile (or
> perhaps 2,5, or 10 miles) is on my map. The project units are in feet
> (but I'm not sure that's relevant in the composer?).
No this doesn't matter to much to the composer, but it does to you...
Essentially all you have to think about is this:
If your map scale is say 1:20 000 (feet), then in the 'Map units per bar
unit', you'll probably want 1, and in the 'Segment size (map units)'
you'll likely want 20 000. This will give you a nice scale bar, and you
can specify how many segments to display etc.
Now in your case, if your map units are in feet, but you want to show
miles in the scale bar, then you have to do the conversion yourself.
Since 1 foot = 0.000189393939 miles, or 1 mile = 5280 feet you can
simply change the 'Map units per bar unit' value from 1 to 5280.
Now, if you are still getting funny things happening, it could be that
your map units are indeed not in feet, in which case, you'll have to
figure out what they really are ;-)
If I'm completely wrong here, please someone let me know, otherwise, I
hope this helps...
Cheers,
Carson
Carson J. Q. Farmer
ISSP Doctoral Fellow
National Centre for Geocomputation (NCG),
Email: Carson.Farmer at gmail.com
Web:   http://www.carsonfarmer.com/
       http://www.ftools.ca/
