[Qgis-user] Problems installing QGIS 1.0.2 on Windows XP
Mike Toews
mwtoews at sfu.ca
Thu Jul 9 07:59:21 PDT 2009
Gavin,
Try installing both VC 2005 and VC 2008 redistributable packages:
http://www.microsoft.com/downloads/details.aspx?familyid=32bc1bee-a3f9-4c13-9c99-220b62a191ee&displaylang=en
Also, I assume you have an x86 computer. If you have a 64 bit computer
or something else, then there are different redistributable packages for
those platforms. If so, the links for the IA64 and x64 packages are
available on the x86 pages. (But even then, I'm not even sure if QGIS
works with these systems.)
-Mike
Gavin Fleming wrote:
> vcredist doesn't fix for me.
> I installed 1.0.2 on XP, then vcredist, reinstalled 1.0.2 and now the error
> is "The application failed to initialise properly".
> Jo Cook wrote:
>> Hi,
>> Yes, that definitely seems to fix the problem.
>> Thanks!
>> Hi Tim,
>> 2009/5/16 Tim Sutton <lists at linfiniti.com>:
>>> Can you try installing this:
>>> http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
>>> And then report back if it runs ok after that?
>>> Thanks
>> QGIS works fine after installing this C++ thingy.
>> Thanks
>> Milena
