[Qgis-user] Wrong reprojection if using different datums?
Agustin Lobo
alobolistas at gmail.com
Sun Jul 12 04:02:03 PDT 2009
I'm converting a shape of points in UTM 31N ED50
to lon,lat WGS84 using the save as... option
under File in QGIS. I've found that I get
the same lon, lat coordinates regardless
I select WGS84 or ED50 for the output shape. This
is not the case using Global Mapper:
QGIS UTM 31N ED50 POINT(449919.586269 4631874.109627)
TRANSFORMS TO LONGITUDE,LATITUDE:
QGIS ED50 POINT(2.396864 41.836439)
QGIS WGS84 POINT(2.396864 41.836439)
GlobalMapper ED50 2.39686371° E 41.83643863° N
GlobalMapper WGS84 2.39572870° E 41.83535625° N
I cannot guarantee that Global Mapper is right, of course,
but doesn't it make sense that the coordinates be
different in both datums? I suspect that proj4 (behind QGIS)
is not using the +towgs= field.
Any opinions on this problem?
Thanks
Agus
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090712/c498acdc/attachment.vcf>
