AW: [Qgis-user] QGis crash at editing
Agustin Lobo
alobolistas at gmail.com
Fri Jul 17 09:48:24 PDT 2009
My hope was that the error messages recorded in the file qgisout.txt
would help. The project involves many layers, so it will be
a long task finding out if this is caused by any of them. Regarding
the edit tool,
the crash occurs when I try to edit a lines layer, even if I start
one with "New layer" and as soon as I try to mark the first point:
I can click but the line does not appear and qgis crashes when I release
the mouse button.
I'll try with the svn version, I did it once, hopefully I'll be able to
do it
this weekend. I'll let you know.
Thanks!
Agus
Hugentobler Marco wrote:
> Hi Agus
> Difficult to say something without knowing the dataset and without knowing which edit tool you used.
> Do you have access to a svn version to see if the problem is still there?
> Regards,
> Marco
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Agustin Lobo
> Gesendet: Fr 17.07.2009 11:51
> An: qgis-user
> Betreff: [Qgis-user] QGis crash at editing
> I'm having the following problem with qgis 1.1.0 for ubuntu:
> - I load a project
> - I select a vector layer to be edited
> - As soon as I try to edit, qgis crash with segmentation fault.
> I've saved error output to:
> http://sites.google.com/site/eospansite/dummy/qgisout.txt
> with
> qgis 2> qgisout.txt
> Thanks for any advice
> Agus
> Qgis-user mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090717/568c5e85/attachment.vcf>
