[Qgis-user] [Fwd: Re: Problem with gdal-mrsid-src]
    Agustin Lobo
    alobolistas at gmail.com
    Fri Jun  5 11:28:38 PDT 2009
This is just to report that the
gdal-mrsid-src library on ubuntugis unstable
is not working yet, but the developers
are working on it.
I'll keep posted the list.
Agus
-------- Original Message --------
Subject: Re: Problem with gdal-mrsid-src
Date: Thu, 4 Jun 2009 14:09:28 -0400
From: Alan Boudreault <aboudreault at mapgears.com>
Organization: Mapgears
To: Agustin.Lobo at ija.csic.es
CC: Jürgen E. Fischer <jef at norbit.de>
References: <20090530203254.4919.55334.launchpad at gangotri.canonical.com>
<200906031249.14739.aboudreault at mapgears.com> <4A280737.3090304 at gmail.com>
Hi Agustin,
This problem has been reported on the UbuntuGIS mailing list and I'm going to
investigate in it as soon as I can.
Thanks,
Alan
On June 4, 2009 01:41:11 pm Agustin Lobo wrote:
> More testing:
> 1. In the intrepid machine:
> While gdalinfo --formats lists mrsid, I get the following error at reading:
> $ gdalinfo N-31-50_2000.sid
> gdalinfo: symbol lookup error: /usr/lib/gdal16plugins/gdal_MrSID.so:
> undefined symbol: _ZN12LTIVSIStreamC1Ev
> 2. This is the same error that I get in QGIS: at reading a mrsid file,
> qgis crashes and the same message is found in the terminal.
> 3. In the hardy machine.
> While the installation works, gdalinfo --formats does not
> list mrsid and:
> ERROR 1: /usr/lib/gdal16plugins/gdal_MrSID.so: undefined symbol:
> _ZNSs20_S_empty_rep_storageE
> ERROR 4: `N-31-50_2000.sid' not recognised as a supported file format.
> gdalinfo failed - unable to open 'N-31-50_2000.sid'.
> Hope this helps! Let me know if can do anything more.
> Thanks a lot for your work
> Agus
> Alan Boudreault wrote:
> > Hi Agustin,
> > I've found the problem. There was a bug in the libgeotiff package. I
> > compiled a new package and uploaded it in UbuntuGIS. Now, everything
> > should ok with gdal-mrsid-src after updating apt-get: `apt-get update`
> > and reinstalling the new version of libgeotif1.2 and libgeotiff-dev.
> > Thanks,
> > Alan
> > On May 31, 2009 01:14:51 pm Agustin Lobo wrote:
> >> Thank you for your interest!
> >> Agus
> >>> Hi Agustin,
> >>> It seems that the autoconf script works in Debian but not in Ubuntu. I
> >>> will check that as soon as I can (probably tomorrow).
> >>> Thank for your report.
> >>> Alan
> >>> Agustin Lobo wrote:
> >>>> Thanks for the many tools in ubuntugis.
> >>>> After downloading and uncompresing
> >>>> Geo_DSDK-7.0.0.2167.linux.x86.gcc32.tar.gz
> >>>> from
> >>>> http://www.lizardtech.com/developer/members/downloads.php
> >>>> (there is also Geo_DSDK-7.0.0.2167.linux.x86.gcc41.tar.gz
> >>>> don't really know which one is better)
> >>>> I've found a problem with gdal-mrsid-src:
> >>>> When I run the GDAL MrSID building script:
> >>>> $ sudo /usr/bin/gdal-mrsid-build /usr/local/Geo_DSDK-7.0.0.2167
> >>>>  I get:
> >>>> configure: error: libgeotiff is required to build GDAL MrSID driver
> >>>> despite having libgeotiff1-2 and libgeotiff-dev
> >>>> It seems there is a broken dependency?
> >>>> I'm using ubuntu 8.04 hardy
> >>>> Thanks
> >>>> Agus
Alan Boudreault
Mapgears
http://www.mapgears.com
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090605/4f93363a/attachment.vcf>
