AW: [Qgis-user] cutting a line removes half of it
    Hugentobler  Marco
    marco.hugentobler at karto.baug.ethz.ch
    Mon Jun 15 04:46:18 PDT 2009
Hi Marco
This problem is fixed now in svn (r10928). Thanks for reporting.
Marco (H.)
-----Ursprüngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org im Auftrag von Marco Lechner - FOSSGIS e.V.
Gesendet: Mo 15.06.2009 10:40
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] cutting a line removes half of it
Hi list, marco and horst,
the error doesn't show up on each cutting action, but if you try the
linked shp-file [1] it should happen every few cutting actions. (just
try to cut lines on several (10-20) locations and it should happen
sometimes).
- Quantum GIS - 1.1.0-Pan (Unstable) 'Pan (Unstable)' (10874M) (on
Debian) with $ geos-config --version 3.1.0
but happens also on Windows/OSGeo-Version 1.0.2 and trunk
- ogrinfo cuttingtest.shp => 1: cuttingtest (Line String)
I also included 2 screenshots into the zip-archive.
Marco Lechner
[1] http://www.marcolechner.de/cuttingtest.zip
Marco Lechner - FOSSGIS e.V. schrieb:
> hi list,
> I'm having a "funny" behaviour while editing a lineshape with QGIS.
> when I try to cut a line in two halfs sometimes the line is properly cut
> and sometimes half of it is removed. I can not reproduce when it works
> right and when it deletes parts of the line
> right: ------------------------------ => ---------------|---------------
> wrong: ------------------------------ => ---------------|
> but it happens on QGIS 1.0.2 on Win as wel as on 1.1.0 Pan on Opensuse
> Any ideas
> Marco
> Qgis-user mailing list
