[Qgis-user] Need Help on Coordinate Capture in Python Plugin
Aaron Racicot
aaronr at z-pulley.com
Tue Jun 16 22:05:28 PDT 2009
Hi there Bruce,
Try to make the SIGNAL signature match the C++ signature as that is what
PyQt will try to match. Specifically you are using Qt.MouseButton (the
Python version) when the C++ version would keep the '::'.
Try:
QObject.connect(self.emitPoint, SIGNAL("canvasClicked(QgsPoint &,\
Qt::MouseButton)"), self.setClipWindow)
Hope that gets you going.
Aaron
Aaron Racicot
Z-Pulley Inc.
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Bruce, Bob (CON)
Sent: Tuesday, June 16, 2009 7:06 PM
To: QGIS User List
Subject: [Qgis-user] Need Help on Coordinate Capture in Python Plugin
Hi:
I am writing a python plugin to clip images to a user selected
rectangle and am stuck at the point where the plugin gets the
coordinates from mouse clicks. Here are some code snippets from my
plugin:
# connect QGSMapCanvas mouse click event to the rubber band clip
window
# function
self.mapCanvas = self.iface.mapCanvas()
self.emitPoint = QgsMapToolEmitPoint(self.mapCanvas)
self.mapCanvas.setMapTool(self.emitPoint)
Qt.MouseButton)"), self.setClipWindow)
def setClipWindow(self, point, button):
QMessageBox.information(self.iface.mainWindow(),\
"ImageClipperDlg Mouse Click Event"," Here are the
coordinates ")
I have tried many variations of the argument lists but I cannot seem to
get the method/function setClipWindow to be called. Can someone see what
I'm doing wrong?
Thanks,
Bob Bruce
** Bob Bruce, P.Eng. Geomatics Support Engineer
** bbruce at gov.mb.ca Manitoba Geomatics/Remote Sensing Branch,
** work # (204) 945-6636 1007 Century Street,
** FAX # (204) 945-1365 Winnipeg, Manitoba, Canada, R3H 0W4
** The Manitoba Centre for:
** Cadastral & Topographical Mapping, and Remote Sensing
** See us on the Web at:
http://www.gov.mb.ca/conservation/geomatics/
** and:
http://www.gov.mb.ca/conservation/geomatics/cada_mapping/index.html
** Check out our digital maps at: http://mlidata.gov.mb.ca/WPMLI
** and: https://mli2.gov.mb.ca/
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
