[Qgis-user] raster catalog: qtsql?
Agustin Lobo
alobolistas at gmail.com
Tue Jun 23 10:38:23 PDT 2009
Yes, indeed. But I cannot find the email
address of the author and it seems he/she is
not listening this list.
Agus
John C. Tull wrote:
> Apparently this has not been addressed. Can anyone confirm if there has
> been progress made on this issue? This would be a useful plugin if I
> understand correctly what it is supposed to do.
> Regards,
> John
> On Jun 15, 2009, at 11:16 PM, Agustin Lobo wrote:
>> Alex,
>> I already had installed both python-qt4 and python-qt4-sql,
>> I can install the plugin with no error messages, but it shows
>> up as incompatible in the plugin manager once
>> installed and qgis restarted.
>> Agus
>> (is the author JJL listening this list? Could not find any message
>> from him/her
>> and cannot cc)
>> Alex Mandel wrote:
>>> Hmm, maybe they aren't included in python-qt4 Ubuntu seems to have a
>>> python-qt4-sql package, try that.
>>> Alex
>>> Agustin Lobo wrote:
>>>> Thanks,
>>>> I meant that I already had
>>>> python-qt4 4.3.3.2
>>>> libqt4-sql 4.4.0
>>>> installed.
>>>> After your message, I installed
>>>> libqt4-sql-psql
>>>> libqt4-sql-sqlite
>>>> libqt4-sql-odb
>>>> but still was geting the same message in qgis:
>>>> "The plugin depends on some components missing on your system. You need
>>>> to install the following Python module in order to enable it: QtSql"
>>>> I've now installed
>>>> python-qt4-sql
>>>> and finally could install the plugin. Nevertheless, after restart, the
>>>> plugin is greyed as incompatible in the plugin manager.
>>>> I'm using Qgis 1.1.0 Pan Uunstable)
>>>> Thanks
>>>> Agus
>>>> Andreas Neumann wrote:
>>>>> You need both.
>>>>> libqt4-sql is for C++ and also the foundation for other script
>>>>> bindings
>>>>> like python (correct me if I'm wrong).
>>>>> python-qt4 are the python bindings for Qt4, it includes qtsql
>>>>> bindings.
>>>>> You probably also need one of the following packages:
>>>>> libqt4-sql-psql (Postgres support)
>>>>> libqt4-sql-sqlite (SQlite 3 support)
>>>>> or any other db you want to support.
>>>>> Andreas
>>>>> On Mon, June 15, 2009 8:17 am, Agustin Lobo wrote:
>>>>>> I've tried to install (on qgis 1.1.0) the raster catalog plugin
>>>>>> and I 'm
>>>>>> told
>>>>>> that Qtsql is required, but which package exactly? According to
>>>>>> Synaptic I have python-qt4 4.3.3.2 and libqt4-sql 4.4.0
>>>>>> Thanks
>>>>>> Agus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> <alobolistas.vcf>_______________________________________________
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090623/a7f6e32f/attachment.vcf>
