[Qgis-user] Need Help
Sebastian Cruz
cruz.seb at gmail.com
Wed Jun 24 16:47:09 PDT 2009
Hello
Could someone help me understand why I have this message every time I
start QGIS? And what the solution could be. If I try to acces the
Plugin Manager QGIS crashes. I have made sure all dependencies are
installed beforehand. I do am not sure how to proceed. I know it is a
python issue, should I reinstall it?
Any help is much appreciated
Thank you
MESSAGE: Python error
Couldn't load plugin "HomeRange_plugin" from ['/Applications/Qgis.app/
Contents/MacOS/share/qgis/python', '/Users/sebastiancruz/.qgis//python/
plugins', '/Applications/Qgis.app/Contents/MacOS/share/qgis/python/
plugins', '/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-
packages', '/System/Library/Frameworks/Python.framework/Versions/2.5/
lib/python25.zip', '/System/Library/Frameworks/Python.framework/
Versions/2.5/lib/python2.5', '/System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/plat-darwin', '/System/
Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-
mac', '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/
python2.5/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/
Python.framework/Versions/2.5/Extras/lib/python', '/System/Library/
Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk', '/
System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/
lib-dynload', '/Library/Python/2.5/site-packages', '/System/Library/
Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC',
'~/.qgis/python', '/Users/sebastiancruz/.qgis/python/plugins/fTools/
tools']
File "", line 2, in
File "/Users/sebastiancruz/.qgis//python/plugins/HomeRange_plugin/
__init__.py", line 32, in
from HRplugin_main import HRPlugin
HRplugin_main.py", line 40, in
from HRplugin_dialog import Dialog
HRplugin_dialog.py", line 44, in
from HRplugin_algorithm import *
HRplugin_algorithm.py", line 46, in
import rpy2.robjects as robjects
File "/Library/Python/2.5/site-packages/rpy2/robjects/__init__.py",
line 12, in
import rpy2.rinterface as rinterface
File "/Library/Python/2.5/site-packages/rpy2/rinterface/
__init__.py", line 6, in
R_HOME = os.popen("R RHOME").readlines()
IOError: [Errno 4] Interrupted system call
Python version:
2.5.1 (r251:54863, Feb 6 2009, 19:02:12)
[GCC 4.0.1 (Apple Inc. build 5465)]
Python path:['/Applications/Qgis.app/Contents/MacOS/share/qgis/
python', '/Users/sebastiancruz/.qgis//python/plugins', '/Applications/
Qgis.app/Contents/MacOS/share/qgis/python/plugins', '/Library/
Frameworks/GDAL.framework/Versions/1.6/Python/site-packages', '/System/
Library/Frameworks/Python.framework/Versions/2.5/lib/python25.zip', '/
python2.5', '/System/Library/Frameworks/Python.framework/Versions/2.5/
lib/python2.5/plat-darwin', '/System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/plat-mac', '/System/
mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/
Versions/2.5/Extras/lib/python', '/System/Library/Frameworks/
Python.framework/Versions/2.5/lib/python2.5/lib-tk', '/System/Library/
Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-dynload', '/
Library/Python/2.5/site-packages', '/System/Library/Frameworks/
Python.framework/Versions/2.5/Extras/lib/python/PyObjC', '~/.qgis/
python', '/Users/sebastiancruz/.qgis/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090624/a4f2a327/attachment.html>
