[Qgis-user] Importing USGS DEMs
John C. Tull
john.tull at wildnevada.org
Sat Jun 27 20:56:08 PDT 2009
It works fine for me in qgis 1.0.2 as well as 1.2.0. What version of
gdal? Mine is 1.6.0.
My layer properties are set to single gray band using band 1 and a
grayscale colormap. Also, the contrast enhancement setting is "Stretch
to MinMax".
John
On Jun 27, 2009, at 3:01 PM, Brook Milligan wrote:
> John C. Tull writes:
>> Likely, you need to set the color options in the layer properties.
>> I'm
>> not too familiar with how you do that correctly, but maybe someone
>> else will suggest the right steps.
> Yes, it seems that I can display the data using the 'pseudocolor' or
> 'freak out' (what exactly is that?) color maps. The 'grayscale' color
> map just gives a solid gray rectangle, whereas the 'colormap' option
> gives just a blank background. I would prefer a simple grayscale
> image.
> Any suggestions on how to accomplish this with qgis 1.0.2 compiled
> from source?
> Thanks for your help.
> Cheers,
> Brook
