[Qgis-user] [Fwd: Problem at starting QGIS and at uninstallingthrough osgeo4w-setup]
Gavin Fleming GavinF at mintek.co.za
Tue Mar 3 02:48:38 PST 2009
Seems to be related to Agus' problem:
I downloaded the 'CD equivalent' from http://trac.osgeo.org/osgeo4w/wiki/InstallFromCD and have run the install locally, choosing QGIS and related plugins.
Several dependencies weren't automatically selected (GEOS, proj4, etc) so I went back and manually selected and installed them. However, it's now not able to find "proj_fw.dll" which is not evident anywhere in the install package. (The proj4 pakage is installed). So my install process has come to a halt.
Also, from the package names it appears that it's still only QGIS 1 preview 2 that's in OSGeo4W. Or is it the full QGIS 1.0?
thanks
Gavin Fleming
-------- Original Message --------
Subject: Problem at starting QGIS and at uninstalling through osgeo4w-setup
Date: Sun, 01 Mar 2009 11:58:13 +0100
Reply-To: Agustin.Lobo at ija.csic.es
To: osgeo4w-dev at lists.osgeo.org
Hi!
After around 30 installations of QGIS using osgeo4w
according to directions in:
http://sites.google.com/site/eospansite/qsig-for-windows
(please notify of any improvements that should be done)
I've found only 1 case with a major problem (Win XP machine)
and I would most appreciate your help.
At starting QGIS, the following message is displayed and the program
does not start:
"Error at starting the program because jpeg_osgeo.dll could not be
found. Reinstaling the program could solve the problem"
(this is my own translation of the original message in Spanis:
"Error al iniciar la aplicación porque no se encontró jpeg_osgeo.dll. La
reinstalación de la aplicación puede solucionar el problema")
(I was not present while the student made the actual installation, so
cannot guarantee that he followed the directions above strictly).
The problem is that we have tried to uninstall through osgeo4w-setup
but don't get to make a complete uninstall, there are always
remaining items. We've uninstalled as much as we could, and installed
again, but the problem remains.
Could you advice on how to proceed for a complete removal and subsequent
successful installation?
Thanks
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This message is intended for the addressee only.
Information and attachments in this e-mail may contain confidential, proprietary, or legally privileged information.
If you are not the intended recipient, or responsible for delivery of the message to the intended recipient,
any disclosure, copying, distribution, or any action taken is prohibited and may be unlawful,
and could result in a claim against you.
