[Qgis-user] Setting a line's length attribute
Matej matej at matnet.net
Tue Mar 3 12:54:09 PST 2009
Hi Andreas,
the solution with a trigger sounds very interesting.
Could you please present more about it?
Thanks,
Matej
matej at matnet.net
----- Original Message -----
To: "qgis-user" <qgis-user at lists.osgeo.org>
Sent: Tuesday, March 03, 2009 8:37 PM
Subject: Re: [Qgis-user] Setting a line's length attribute
> Hi Matej,
> QGIS does not yet have a field calculator or a similar mechanism. But
> since your data is in Postgis already, it is very easy to do it with
> Postgis and SQL:
> UPDATE yourschema.yourtable SET LineLength = ST_Length(the_geom);
> You can even set a row-level trigger so that the length gets
> automatically updated if a geometry changed. Please let me know if you
> are interested in the trigger thing.
> Andreas
> Matej wrote:
>> Hello,
>> I have a PostGIS table which has an attribute "length". I would like
>> to have calculated length of every particular segment (the information
>> that is printed when I click on the Identify Features and then select
>> some line segment) to be somehow "set" into the field length
>> automatically. In MapInfo, this can be achieved by Update column and
>> then setting the ObjectLen to the appropriate field.
>> How can this be done in QGIS?
>> Thanks a lot!
>> Matej
>> matej at matnet.net <mailto:matej at matnet.net>
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
