[Qgis-user] PostGIS layers invalid in 1.0.1
Standaert Arnout
arnout.standaert at vito.be
Mon Mar 9 06:59:05 PDT 2009
Hi list,
I've been using Qgis in the 1.0 previews without problems. Now, with the 1.0.1 release via the online installer (on WinXP), my PostGIS layers do not load anymore. Nothing in the database changed, so this is probably a QGis issue.
The error message is:
Invalid Layer
"public"."tbl_soilconcs" (the_geom) sql= is an invalid layer and cannot be loaded.
First, I suspected an OID problem (the database tables do not have an OID column). Adding an OID to one of the PostGIS tables does not make it work, but loading that table gives me another error message:
Invalid Layer
"public"."tbl_bodemconcs_withoids" (the_geom) sql=GeometryType("the_geom") IN ('POINT','MULTIPOINT') is an invalid layer and cannot be loaded.
So, the "sql=" part is different in this case and contains a WHERE clause.
Can anyone give me a clue on how to fix this? I found another reference to a similar problem over here: http://forum.qgis.org/viewtopic.php?t=227, but it doesn't help me much further...
Thanks a bunch for any ideas,
wwwald
This e-mail, any attachments and the information it contains are confidential and meant only for the use of the addressee(s) only. Access to this e-mail by anyone other than the addressee(s) is unauthorized. If you are not the intended addressee (or responsible for delivery of the message to such person), you may not use, copy, distribute or deliver to anyone this message (or any part of its contents) or take any action in reliance on it. In such case, you should destroy this message and notify the sender immediately. If you have received this e-mail in error, please notify us immediately by e-mail or telephone and delete the e-mail from any computer.
All reasonable precautions have been taken to ensure no viruses are present in this e-mail and its attachments. As our company cannot accept responsibility for any loss or damage arising from the use of this e-mail or attachments we recommend that you subject these to your virus checking procedures prior to use.
