[Qgis-user] Build problem : Pyqt-4.5 on mac osx Leopard
massimo di stefano massimodisasha at yahoo.it
Fri Mar 13 08:34:44 PDT 2009
William, Yes it is ....
infact i done the simlink for both the *Lucene libs :
history | grep ln -s
   490  sudo ln -s /usr/lib/libQtLucene.dylib /Developer/SDKs/
MacOSX10.5.sdk/usr/lib/libQtLucene.dylib
   492  sudo ln -s /usr/lib/libQtCLucene.4.5.0.dylib /Developer/SDKs/
MacOSX10.4u.sdk/usr/lib/libQtLucene.dylib
   493  sudo ln -s /usr/lib/libQtCLucene.4.5.0.dylib /Developer/SDKs/
MacOSX10.4u.sdk/usr/lib/libQtCLucene.dylib
   495  sudo ln -s /usr/lib/libQtCLucene.4.5.0.dylib /Developer/SDKs/
MacOSX10.5.sdk/usr/lib/libQtCLucene.dylib
now tring to come back to qt4.4 .. i had the same error about lucene
missed libs, i'll try again a sm link "only for :"
and see if it solve :-/
Massimo Di Stefano
epifanio on   irc.freenode.net  /join gfoss
Il giorno 13/mar/09, alle ore 15:27, William Kyngesburye ha scritto:
> On Mar 13, 2009, at 3:07 AM, massimo di stefano wrote:
>> thanks to the aid of a friend, he suggest me to create a simlink :
>> the simlink did the job
> hehe - it's amazing this worked - I misspelled the library name, it
> should have been "libQtCLucene.dylib" (note the extra 'C').  Unless
> your brain quietly fixed it for you when you typed it.
> If the compilation here succeeded for some reason after this wrong
> symlink, maybe it's the cause of the dlopen error later.
>> qt-4.5 (dmg binary)
>> sip-4.8-snapshot-20090311
>> PyQt-mac-gpl-4.5-snapshot-20090311
>> are compiled on osx without errors, but unlucky they don't works :-
>> ( running any pyqt4.5 example give me these error :
>> ImportError: dlopen(/Library/Python/2.5/site-packages/PyQt4/
>> QtCore.so, 2): Symbol not found: _sipQtConnect Referenced from: /
>> Library/Python/2.5/site-packages/PyQt4/QtCore.so Expected in:
>> dynamic lookup
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
