[Qgis-user] Re: plugin_installer error
Borys Jurgiel
borysiasty at aster.pl
Mon Mar 16 01:48:43 PDT 2009
Monday 16 March 2009 05:50:42 Nik Go napisaĆ(a):
> I'm confused as to why fTools is working fine but the plugin_installer is
> not.
What Qt version do you use?
Btw. Manual installation of the Plugin installer isn't necessary as it's built
in QGIS. By installing it, you mask the native instance, so you can try to
remove the /home/erwin/.qgis//python/plugins/plugin_installer directory and
restart QGIS. However it probably won't help you in this case.
> > How do I fix this? Why is there a double slash in there?
The double slash doesn't matter.
