[Qgis-user] Help with Python Plug-in issue
Todd Fagin tfagin at coordinatesolutions.com
Wed Mar 18 12:16:01 PDT 2009
Greetings list,
I just installed Kore.  Previously, I was running Metis with a handful of
plug-ins.  When I installed using osgeo4w-setup.exe (I'm using Windows.), I
used the advanced options and selected to also install the python-qgis:
Python Plugin and bindings for Quantum GIS.  However, when I now launch
QGIS, I immediately received a series of Python errors stating "Couldn't
load plugin." The plugins it cannot load are geoprocessing, newlayer,
qgis_rgb, and rasteralgebra.  I assume these can't be loaded because they
were removed when I uninstalled Metis.  I thought the easy solution would be
to just go to the Plugins dropdown menu in QGIS and remove the offending
buggers.  Instead, QGIS locks-up any time I try to open the Plugins dialog.
In attempt to remedy this, I uninstalled the Python plugin, re-launched
QGIS, and cleared all of the selected plugins (of course, the offending ones
aren' t listed).  I then re-installed the Python plugin, but immediately get
the same problem.
This is incredibly frustrating, any suggestions would be greatly
appreciated.
Todd Fagin
Coordinate Solutions, Inc.
2804 NW 18th St.
Oklahoma City, OK 73107
405.740.4324 (voice)
904.471.5548 (fax)
www.coordinatesolutions.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090318/23a7c501/attachment.html>
