[Qgis-user] Projection not recognised EPSG:31259
Helmut Kudrnovsky hellik at web.de
Tue Mar 24 06:53:09 PDT 2009
hi Roland,
ArcGIS 9.3 doesn't include the towgs-paramater in the prj-file.
maybe the original definition of a prj-file doesn't include the towgs-parameter, but gdal/ogr needs this information for a correct gdal-warp.
I know from the ESRI-side that you have to define this parameter manually for a correct on-the-fly-reprojection, the same for GRASS, because there are not unique towgs-parameter in the epsg-db. it depends from the purpose of the data.
best regards
Helli
>Message: 7
>Date: Tue, 24 Mar 2009 12:31:35 +0100
>From: Roland Kaiser <roland.kaiser at sbg.ac.at>
>Subject: Re: [Fwd: Re: [Qgis-user] Projection not recognised
>	EPSG:31259]
>To: qgis-user at lists.osgeo.org
>Message-ID: <C920277D-088B-4DE1-A80A-47C1C6C496B6 at sbg.ac.at>
>Content-Type: text/plain; charset=US-ASCII; delsp=yes; format=flowed
>Werner-
>prj files generated by ERSI products generally lack TOWGS parameters
>(see EPSG:1618, CoordinateTransformation, http://www.epsg-registry.org).
>Maybe this is solved in ARCGIS 9.3.
....  .  .__..  .__.. ..
helmut kudrnovsky
mail: alectoria at gmx.at
internet: www.alectoria.at www.myricaria.org
____________________________________________________________________
Psssst! Schon vom neuen WEB.DE MultiMessenger gehört?
Der kann`s mit allen: http://www.produkte.web.de/messenger/?did=3123
