[Qgis-user] Vector Layer Translate Feature
    Pietro Panzeri
    pietro.panzeri at treuropa.com
    Mon Mar 30 07:21:49 PDT 2009
Il Monday 30 March 2009 14:43:49 Carson Farmer ha scritto:
> Pietro,
> > I'm writing a Python plugin to allow the user to translate a whole vector
> > layer by a given shift.
> > I use the translateFeature() of the QgsVectorLayer class but if the layer
> > is zoomed the function translates only the visualized features.
> > Can someone point me a way to act on the whole layer regardless of the
> > current zoom?
> In your provider.select() call, what do you use for the spatial filter?
> If you want to run through all features in the layer, make sure you
> don't specify any bounds in the rect variable:
> attrs = provider.attributeIndexes()
> provider.select(attrs)
> or if that doesn't work, specify the extent of the layer as the rect
> using layer.extent(), which is inherited from QgsMapLayer...
> Cheers,
> Carson
I use the following code:
vlayer = iface.activeLayer()
provider = vlayer.dataProvider()
f = QgsFeature()
while provider.nextFeature(f):
	error_code = vlayer.translateFeature(f.id(), delta_x, delta_y)
If the feature to translate is not one of the visualized features, the
error_code is 1 and the feature is not translated.
I don't know if this is the correct approach. Please tell me where I'm doing
wrong.
Thank you.
Pietro
Pietro Panzeri
Tele-Rilevamento Europa - T.R.E. s.r.l.
a POLIMI spin-off company
Via Vittoria Colonna, 7
20149 Milano - Italia
tel.: +39.02.4343.121
fax: +39.02.4343.1230
e-mail: pietro.panzeri at treuropa.com
web: www.treuropa.com
