[Qgis-user] raster-catalogue-support
    maning sambale
    emmanuel.sambale at gmail.com
    Thu May  7 02:33:27 PDT 2009
+1 here.
Stephen, as a workaround, I use a local wms to load 500+ topographic
maps in QGIS, using the generated index.shp from gdaltindex.
An example map file is like this:
LAYER
    NAME 'Topo_Sheet'
    STATUS ON
    TILEINDEX '/__/toposheets/topo_index.shp'
    TILEITEM 'location'
    TYPE RASTER
    PROCESSING "DITHER=YES"
    PROJECTION
	"+proj=longlat +ellps=clrk66 +no_defs"
    END
  END
The WMS layer will load only the tiles you need within the QGIS mapwindow.
On Thu, May 7, 2009 at 5:25 PM, Stephan Holl <stephan.holl at intevation.de> wrote:
> Hi QGIS-users,
> does someone know if QGIS has an option to read raster-catalogues (as
> the ones usable for MapServer generated with tileindex)?
> If yes, I would be interested how to use.
> If not, it does not seem too difficult to create a python-plugin to
> support this sort of layers.
> TIA
>        Stephan
> Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
> Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
> Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
