[Qgis-user] QGIS Language Problem
Borys Jurgiel borysiasty at aster.pl
Thu May 7 04:37:14 PDT 2009
Thursday 07 of May 2009 13:14:00 kovuri suresh napisaƂ(a):
> Hi.... folks
> How can i get English version of QGIS Desktop , because
> i am living in Dutch land... so when i downloaded from website ...... i
> got Dutch version ....i am not familiar with Dutch ........so is there
> any possibility to change the language or can i get the English version
> in Dutch land also ..............
There is only one, multilingual version. Unfortunately, you can easily force any
language BUT English (I'll try to fix it for the qgis 1.2). If you want to force
English on an operating system set to Dutch, the only way is to call qgis with
parameter --lang=en
So if you calling qgis with desktop or menu shortcut, you need adjust its
properties by changing the command form "qgis" to "qgis --lang=en"
If you want to force any other language supported by QGIS, it's much simpler.
Just go to the menu Extra -> Opties... -> Locale tab, check the "Systeem locale
negeren" and choose the desired language.
