[Qgis-user] QGIS Language Problem
Borys Jurgiel borysiasty at aster.pl
Thu May 7 05:54:54 PDT 2009
Thursday 07 of May 2009 14:35:29 Agustin Lobo napisaƂ(a):
> Suresh,
> Just select Options/Locale and select Override system locale, en_US
> should be the default
> (the first time you must be able of finding Options/Locale in Dutch)
> Then exit and restart. Should be in English
No, it won't work, because the en_US is not listed unless it is the present
locale. The only way is with the call parameter.
The list contains just the present locale and all the .ts files. It's a bug of
course and I (or someone faster) will fix it for the 1.2 - the first item should
be rather the en_US instead of the present locale.
