[Qgis-user] Solved: raster-catalogue-support
Stephan Holl
stephan.holl at intevation.de
Fri May 8 05:39:56 PDT 2009
Hello Stephan,
Stephan Holl <stephan.holl at intevation.de>, [20090508 - 14:24:26]
> Hello Stephan,
> Stephan Holl <stephan.holl at intevation.de>, [20090507 - 12:16:37]
> > Hello Jürgen, Horst, Emmanuel,
> > Jürgen E. Fischer <jef at norbit.de>, [20090507 - 11:42:31]
> > > Hi Stephan,
> > > On Thu, 07. May 2009 at 11:25:59 +0200, Stephan Holl wrote:
> > > > does someone know if QGIS has an option to read
> > > > raster-catalogues (as the ones usable for MapServer generated
> > > > with tileindex)?
> > > You can use GDAL vrt files - which you can create using
> > > gdalbuildvrt[1]. Never done that myself yet, but that's where I'd
> > > start.
> > Thanks for your hints, I will certainly try your suggestions
> > regarind the VRT-files.
> > /me just built gdalbuildvrt
> Well, this works on linux like a charme, but on Windows I cannot
> manage to make it work with qgis1.0.1 from osgeo4win-installation.
> Any thoughts? TIA
Sorry for the noise, I had to manually set 'relativeToVRT="1", then it
worked.
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090508/1b194e86/attachment.sig>
