[Qgis-user] Ubuntu version of QGIS - some crashes and bugs
Giovanni Manghi
giovanni.manghi at gmail.com
Sun May 10 09:36:03 PDT 2009
> Hello again
> I decided to uninstall and follow Giovanni's compilation guide (very
> nice guide by the way). Compiled qgis 1.0.2 (rev 10759) and now the
> symbology crash issue is finally gone.
By the way, you can use Les-ejk UbuntuGIS repository, it has qgis 1.0.1
compiled against gdal 1.6.0, so without this bug.
> Concerning the slow print composer, the problem remains. Can anyone
> offer some insight on this?
> The problem is, whenever I add a map a new map in the print composer,
> after selecting the maps dimensions, qgis takes more than a minute
> (maybe more than two minutes) to respond. After that, if I try to
> update the map the same lag happens. If I add other stuff to the map
> (scale, legend, ...) it displays normally.
I can't replicate the problem here. What kind of map give you this
problem? Now you compiled why not giving a try to 1.1.0?
-- Giovanni --
