[Qgis-user] Editing attributes
Alex Mandel tech_dev at wildintellect.com
Tue May 12 14:21:29 PDT 2009
Kurt Springs wrote:
> I am trying to label certain sites.  I originally used ascii files to
> put the sites into GRASS.  However, this leaves some ascii codes in the
> labels in Qgis.
> For example, the label comes out:  #1 %51 @"Cat. 51".  All I need is
> Cat. 51 to appear on the map.  This is in column str_1.  The "toggle
> editing mode" button is grayed out.  How can I edit this column?
> Thanks for any help.
> Kurt
Is this a GRASS layer? What backend did you use for the attribute table?
If it's dbf, just open the dbf in excel or openoffice calc edit and save
back to dbf. The files should be in your mapset directory under a dbf
folder. If you used a database backend the answer will vary by database.
Alex
