[Qgis-user] Re: Qgis-user Digest, Vol 39, Issue 16
Kurt Springs ferret_bard at mac.com
Wed May 13 06:17:13 PDT 2009
It started life as an ascii file I created in Barebone Textwrangler.
I imported it into GRASS using v.in.ascii to create point vectors,
hence the extra code.  I just need a way to clean up the unnecessary
code to create labels for  my maps I intend to put in my dissertation.
Kurt
On May 13, 2009, at 3:17 AM, qgis-user-request at lists.osgeo.org wrote:
> Kurt Springs wrote:
>> I am trying to label certain sites.  I originally used ascii files to
>> put the sites into GRASS.  However, this leaves some ascii codes in
>> the
>> labels in Qgis.
>> For example, the label comes out:  #1 %51 @"Cat. 51".  All I need is
>> Cat. 51 to appear on the map.  This is in column str_1.  The "toggle
>> editing mode" button is grayed out.  How can I edit this column?
>> Thanks for any help.
>> Kurt
> Is this a GRASS layer? What backend did you use for the attribute
> table?
> If it's dbf, just open the dbf in excel or openoffice calc edit and
> save
> back to dbf. The files should be in your mapset directory under a dbf
> folder. If you used a database backend the answer will vary by
> database.
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090513/e78d2972/attachment.html>
