[Qgis-user] problem in getting projection
Bijay Panda
bijaykumar.mail at gmail.com
Thu May 14 21:30:37 PDT 2009
Hi ,
Thanks for ur reply.But I am not allowed to remove and reinstall Qgis.
So how can fix the problem for not getting projection.How can I set the
proper path if there are two different versions in my machine.It may be the
wrong path for srs db.Please help me out.
On Wed, May 13, 2009 at 6:55 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> Bijay Panda wrote:
>> Hi All,
>> I am using Qgis 1.1.0(unstable trunk) in ubuntu 8.04.
>> I installed it my checkout from svn and compilation there after.
>> I have some issues like bellow.
>> 1)While loading qgis application ,it's showing the error like below
>> ERROR 1: libgrass_I.so: cannot open shared object file: No such file or
>> directory
>> directory
> Is grass libs in your library path? You may need to add it to your
> /etc/ld.so.conf or your LD_LIBRARY_PATH if it is not.
>> 2)It's giving segmentation fault while opening some image files like tiff
>> files.
> In order to diagnose why, you would need to build in debug mode and create
> a stacktrace.
> 3)I am unable to get the list of projections when i go for projection
>> properties.
>> Only Geographic Coordinate systems,projected Coordinate system,User
>> defined Coordinate systems
>> are coming but no more option for each category are there.\
> It sounds like you have more than one set of qgis libs in your search path.
> Make sure your from source compiled version is not built into the same dir
> as any other packaged version.
>> Is there any process to remove the installed qgis to reinstall it .
> make uninstall
> Regards
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
Thanks & Regards
Bijay Kumar Panda
Mob-9739591816
bijaykumar_panda at yahoo.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090515/0fcfc43c/attachment.html>
