[Qgis-user] join image bands
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Mon May 25 19:16:35 PDT 2009
Hi Nikos,
Thanks for your reply. As I just installed QGis on Vista,
I never loaded or run a plugin. How can I do that?
Bests
milton
2009/5/25 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> Milton:
> > I have three tif files, one for each landsat image,
> > and I would like to join the bands on one file.
> > Can I do this on Qgis?
> Hi! There is an "RGB Composition" qgis-plugin available for that. But it
> doesn't work for me (error below)?
> Nikos
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/nik/.qgis//python/plugins/rgb/Rgb.py", line 49, in makergb
> composite.rgb(str(self.pluginGui.comboBox_3.currentText()),str(self.pluginGui.comboBox_4.currentText()),str(self.pluginGui.comboBox_5.currentText()),str(self.pluginGui.lineEdit.text()))
> File "/home/nik/.qgis//python/plugins/rgb/composite.py", line 15, in
> rgb
> x=r.RasterXSize
> AttributeError: 'NoneType' object has no attribute 'RasterXSize'
> Python version:
> 2.6.2 (release26-maint, Apr 19 2009, 02:15:38)
> [GCC 4.3.3]
> Python path:['/usr/local/share/qgis/python',
> '/home/nik/.qgis//python/plugins/symbology_ng',
> '/home/nik/.qgis//python/plugins',
> '/usr/local/share/qgis/python/plugins',
> '/usr/local/lib/python2.6/dist-packages/GDAL-1.6.0-py2.6-linux-x86_64.egg',
> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
> '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/Numeric',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10',
> '/var/lib/python-support/python2.6',
> '/usr/lib/python2.6/dist-packages/gtk-2.0',
> '/var/lib/python-support/python2.6/gtk-2.0',
> '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/local/lib/python2.6/dist-packages',
> '/usr/local/share/qgis/python/plugins/fTools/tools', '~/.qgis/python',
> '/usr/share/qgis/python']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20090525/f77e1e2b/attachment.html>
