[Qgis-user] gps plugin
Micha Silver
micha at arava.co.il
Sat May 30 01:23:25 PDT 2009
mtnbiketrail at zzz.com wrote:
> I used the gps plugin to load a gpx file, but it switches the lat and
> long around and so won't match up with my raster geotiff. The mouse
> pointer coords actually show -123, 41 instead of 41, -123.
> This came from a garmin Mapsource generated gpx file.
The problems of "axis order"[1] are a real bugger. I didn't know that
Mapsource reversed the order. Here's an idea how to reverse the order
of the Mapsource gpx files to get the lat and long correct:
The proj4 utility cs2cs has a '-r' option to reverse x-y to y-x. But to
use it, cs2cs expects a simple text list of coordinates (not the xml
formatted gpx file). So you would first have to use gpsbabel to convert
like so:
gpsbabel -i gpx -o csv <waypoints.gpx> <waypoints.csv>
Now edit that new csv file to *remove* all the commas. Then you can run:
cs2cs -r +init=epsg:4326 +to +init=epsg:4326 waypoints.csv >>
waypoints_fix.txt
And finally use gpsbabel again to revert this new waypoints_fix.txt back
to gpx format.
It's pretty convoluted, but *might* work...
Regards,
Micha
[1] http://wiki.osgeo.org/wiki/Axis_Order_Confusion
> Any suggestions?
> thanks,
> Tom
> Using 1.0.0 on Ubuntu heron.
> I also tried it on 1.0.1 on Windows XP
> Qgis-user mailing list
> This mail was received via Mail-SeCure System.
