[Qgis-user] qgis & mrsid used to work
M S
mseibel at gmail.com
Mon Nov 2 10:58:22 PST 2009
gdalinfo --version returns GDAL 1.6.2
if I do 'sudo apt-get remove gdal1-1.5.0' it wants to remove all this:
The following packages were automatically installed and are no longer required:
proj libgdal1-1.6.0-grass
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
libgdal1-1.5.0 libqgis1.3.0 python-qgis python-qgis-common qgis
qgis-common qgis-plugin-grass qgis-plugin-grass-common
And if I 'apt-get install qgis', it wants to put gdal 1.5.0 back.
Is there something with the ubuntugis/unstable repo perhaps?
Thanks,
Mark
On Mon, Nov 2, 2009 at 1:35 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
> M S wrote:
>> I had a working QGIS and Mr SID, but just did an update to Karmic
>> which installed new qgis and grass (same versions?) and subsequently
>> broke the mr sid relationship (I cant add MR SIDs to QGIS).
>> I am using this site to install
>> http://n2.nabble.com/Directions-to-get-mrsid-support-in-GQIS-and-other-packages-using-gdal-on-Ubuntu-td3169342.html
>> Everything seems fine with the creation of gdal_MrSID.so.
>> gdal_GRASS.so, gdal_MrSID.so and ogr_GRASS.so are all in the
>> /usr/lib/gdal16plugins directory. nothing is in the
>> /usr/lib/gdal15plugins directory.
>> I notice that libgdal1.5 gets installed from the ubuntu repo, while
>> additionally libgdal1.6 gets installed from the ubuntugis directory.
>> gdalinfo --formats lists MR SID as a recognized format, but QGIS
>> doesnt have it in the list nor recognizes it as GDAL raster.
>> Thanks,
>> Mark
> Which gdalinfo are you using. Good chance you installed it for libgdal
> 1.5 instead of 1.6. Try removing all the 1.5 stuff and redo the MRSID
> install.
> Alex
> Qgis-user mailing list
