[Qgis-user] Building qgis2google on Mac
Don MacQueen macq at llnl.gov
Wed Nov 4 17:58:06 PST 2009
I downloaded the source code using
    svn checkout http://svn.gis-lab.info/qgis2google2 qgis2google2
Then, on Macintosh (OS version 10.5.8) I get
build[91]% cmake ../qgis2google2
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
CMake Error at CMakeLists.txt:28 (QT4_WRAP_UI):
   Unknown CMake command "QT4_WRAP_UI".
The CMake error looks as if it is a problem in
the CMakeLists.txt file, rather than a problem
with missing dependencies in my system, but it's
hard for me to know, since I'm unfamiliar with
CMake.
I have installed QT 4.5.3 from a binary download at
    http://qt.nokia.com/downloads
I installed cmake from a binary download for Mac at
   http://www.cmake.org/
build[100]% cmake --version
cmake version 2.6-patch 4
Suggestions would be welcome!
Thanks
-Don
p.s.
I have no idea what "the usual way it's done for
other plugins" is. Although I have generally been
successful following instructions to "configure,
make, make install" for a variety of open source
projects, I am not a QGis plugin developer.
At 11:33 AM +0200 10/21/09, G. Allegri wrote:
>Hi Barend,
>I forward your request to the list, as you
>probably have submitted it only to me.
>Anyway I think you shouldn't have problems to
>compile it under your platforms, the usual way
>it's done for the other plugins, as the
>CmakeLists is provided in the svn.
>Giovanni
>2009/10/21 Barend Köbben <<mailto:kobben at itc.nl>kobben at itc.nl>
>When can we expect a multi-platform verison...?
>On 20-10-09 19:16, "G. Allegri"
><<mailto:giohappy at gmail.com>giohappy at gmail.com>
>wrote:
>>  Compliments for the plugin. I've just tried
>>it. It works very well and I find
>>  it's really useful.
>>  Thank you very much!
>>  Giovanni
>>  2009/10/20 Maxim Dubinin <<mailto:sim at gis-lab.info>sim at gis-lab.info>
>>>  Hi all,
>>>  a little announcement, we've made a new version of our plugin. It
>>>  gives QGIS several tools for interacting with Google Earth. You can
>>>  quickly send a feature or the whole layer to GE keeping current layer
>>>  symbology or override it with your own one. Unique values and single
>>>  symbol legends are supported.
>>>  More info:
>>><http://*gis-lab.info/qa/qgis2google-eng.html>http://*gis-lab.info/qa/qgis2google-eng.html
>>>  It is tested and working under Windows/OSGeo4W/trunk and source code is
>>>  available
>>>  for linux hackers.
>>>  Maxim
>>>  PS: I've recorded a video to have a look how it works, but it turned out
>>>  to be huge (100 mb) and I couldn't compress it to more reasonable size. You
>>>  can still see
>>>  it, if this is not a problem for you.
>>>  _______________________________________________
>>>  Qgis-user mailing list
>  >> <mailto:Qgis-user at lists.osgeo.org>Qgis-user at lists.osgeo.org
><http://*lists.osgeo.org/mailman/listinfo/qgis-user>http://*lists.osgeo.org/mailman/listinfo/qgis-user
>International Institute for Geo-Information
>Science and Earth Observation (ITC)
>Chamber of Commerce: 410 27 560
>E-mail disclaimer
>The information in this e-mail, including any
>attachments, is intended for the addressee only.
>If you are not the intended recipient, you are
>hereby notified that any disclosure, copying,
>distribution or action in relation to the
>content of this information is strictly
>prohibited. If you have received this e-mail by
>mistake, please delete the message and any
>attachment and inform the sender by return
>e-mail. ITC accepts no liability for any error
>or omission in the message content or for damage
>of any kind that may arise as a result of e-mail
>transmission.
Don MacQueen
Environmental Protection Department
Lawrence Livermore National Laboratory
Livermore, CA, USA
925-423-1062
