[Qgis-user] SDA4PP
Volkan Kepoglu
vkepoglu at gmail.com
Fri Nov 6 00:53:41 PST 2009
rggobi and iplots packages are required for tool: Rggobi and Linked
Statistical Display in the SDA4PP.
the rest of the tool in the plugin do not use two package. So, the plugin
should work without installing two package if you do not use these two tool.
Volkan Kepoglu wrote:
> Hi, Marco,
> rggobi and iplots have several dependencies. you should also install them.
> rgobi's dependencies:
> 1. ggobi [reguires gtk]
> 2. RGtk2 package in the R.
> iplot is:
> 1. rJava
> Did you see this page:
> http://ggit.metu.edu.tr/~volkan/development_environment.html
> Regards,
> volkan osman kepoglu
> marcozanieri at geosweb.it wrote:
>> Hi, i installed SDA4PP on Qgis 1.3 for winxp,
>> now the libraries "mgcv,rgdal,maptools and spatstat" work
>> well, the
>> problems remain about libraries "rggobi and iplots", the
>> messages are the same:
>> R library; rggobi could not be loaded.
>> Please install ' rggobi ' package(s).
>> R library; iplots could not be loaded.
>> Please install ' iplots ' package(s).
>> I don't understand why because I installed these libraries
>> in R in the same
>> way of the others, that now are ok....
>> thanks all!
>> marco zanieri
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
View this message in context: http://n2.nabble.com/SDA4PP-tp3955302p3957595.html
Sent from the qgis-user mailing list archive at Nabble.com.
