[Qgis-user] seting up a wms server problems
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Mon Nov 9 10:56:57 PST 2009
Hi Micha, David and list
I have the WMS working fine now! Micha's tip of adding an EXTENT field
at the LAYER level solved it. Thanks a lot!
On Mon, Nov 9, 2009 at 6:43 PM, David Fawcett <david.fawcett at gmail.com> wrote:
> Ricardo,
> This is probably a better question for the MapServer list, but I will
> give it a shot:
> I would suggest creating a WMS request and testing it directly in a
> browser.  In your example URL[2], you are making a mode=map request,
> not a WMS request.  If you get this to work, you know that you have a
> working WMS server.
> I am wondering if the issue with the WMS request not working is due to
> the spatial reference system used by your QGIS project.
> David.
> On Sat, Nov 7, 2009 at 9:20 PM, Ricardo Filipe Soares Garcia da
> <ricardo.garcia.silva at gmail.com> wrote:
>> Hello list
>> I've been trying to set up a wms server on my laptop for testing
>> purposes but I can't seem to make it work.
>> I'm using mapserver, having installed version 5.4.2 as supplied by the
>> ubuntugis-unstable repository for ubuntu 9.10, which is my operating
>> system.
>> I created the mapfile[1], tested the GetCapabilities request through a
>> web browser (it came out without any warnings) and I can see my map
>> through shp2img and also through a web browser[2]. However, I cannot
>> see it through Qgis. I am defining my wms server with the following
>> connection string:
>> http://pig/cgi-bin/mapserv?map=/home/ricardo/Public/public_html/pig/mapfiles/teste.map
>> ('pig' is just the name I gave to my apache virtual host, so that is
>> why it is there, instead of 'localhost')
>> I can connect to the server and see the available layers, but when I
>> select one layer to be loaded Qgis acts like it loaded the layer but I
>> get only a blank image that is not even showing up in the place that
>> it was supposed to.
>> Maybe this question would be better suited for the mapserver
>> mailing-list but I can see the map through a browser, so I am guessing
>> that my mistake is in the definition of the wms server inside Qgis...
>> Please note that I can use the default wms servers that come with Qgis
>> (the JPL, Lizardtech and DMSolutions) without any problem.
>> As a side note, I tried the same thing with Kosmo and the result was
>> the same. I can see the available layers but when I load a layer the
>> result is just a blank image. Through Kosmo I can even see the legend
>> of the map, which appears fine, showing my 2 classes and their color..
>> Thanks for helping me out
>> [1] - mapfile named teste.map follows:
>> # testes para mapfile para PIG
>> map
>>    name "nomeServWMS"
>>    status on
>>    size 800 600
>>    extent -89082.193 -100704.460 -88936.384 -100604.0546
>>    units meters
>>    imagecolor 255 0 255
>>    imagetype png
>>    projection
>>        "init=epsg:27492"
>>    end
>>    web
>>        imagepath "/home/ricardo/Public/public_html/pig/temp_images/"
>>        imageurl "/temp_images"
>>        log testes.log
>>        header "/home/ricardo/Public/public_html/pig/templates/header.html"
>>        template "/home/ricardo/Public/public_html/pig/templates/blank.html"
>>        footer "/home/ricardo/Public/public_html/pig/templates/footer.html"
>>            metadata
>>                wms_title "titulo do servico"
>>                wms_abstract "pequena descricao do servico wms"
>>                wms_onlineresource
>> "http://pig/cgi-bin/mapserv?map=/home/ricardo/Public/public_html/pig/mapfiles/teste.map&"
>>                wms_srs "epsg:27492"
>>            end
>>        end
>>    layer
>>        name salasP1
>>        type polygon
>>        status on
>>        connectiontype postgis
>>        connection "host=localhost dbname=pigTeste user=gisuser
>> password=resusig"
>>        #data "the_geom from (select * from sala where pi_gid=1) as
>> salaP1 using unique sa_gid using srid=27492"
>>        data "the_geom from salasp1 using unique sa_gid using srid=27492"
>>        template "../templates/blank.html"
>>        dump true
>>        projection
>>            "init=epsg:27492"
>>        end
>>        metadata
>>            wms_title "salasP1tit"
>>            wms_abstract "Breve descricao"
>>            wms_keywordlist "teste"
>>            wms_include_items "all"
>>            gml_include_items "all"
>>            wms_feature_info_mime_type "text/plain"
>>        end
>>        classitem "tipo"
>>        class
>>            name "WC"
>>            expression "Casa de banho"
>>            style
>>                color 232 232 232
>>                outlinecolor 0 0 0
>>            end
>>        end
>>        class
>>            name "Sala"
>>            expression "Sala"
>>            style
>>                color 255 0 0
>>                outlinecolor 0 0 0
>>            end
>>        end
>>    end
>> end
>> [2] - calling it as
>> http://pig/cgi-bin/mapserv?map=/home/ricardo/Public/public_html/pig/mapfiles/teste.map&service=wms&mode=map&layer=salasP1
>> ___________________________ ___ __
>> Ricardo Garcia Silva
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
