[Qgis-user] Scale dependent rendering connected with attributes of field
Borys Jurgiel borysiasty at aster.pl
Wed Nov 11 07:48:33 PST 2009
Dnia środa, 11 listopada 2009 o 16:02:38 Piotr Pachół napisał(a):
> Hello,
> I would like to ask if in Qgis there is possibility to use scale
> dependent rendering not only connected with whole layer but also with
> attributes in particular field.
> For instance I have one layer of roads classificated in one of field as
> state roads, provincial roads etc. ...
> Now I would like to use different scale dependent rendering for state
> Is it possible ?
> Piotr
Unfortunately, it isn't. You need to add a separate layer for every road type
and scale range.
Martin, do you plan to implement such functionality later in the NG Symbology?
It would be great :)
