AW: [Qgis-user] QGIS WPS Client
Mailing Lists lists at linfiniti.com
Wed Nov 11 12:19:03 PST 2009
Hi
There is also the tutorial I wrote on getting pyWPS running here:
http://linfiniti.com/2009/09/a-quick-quide-to-getting-up-and-running-with-pywps/
Regards
Tim
On Wed, Nov 11, 2009 at 8:52 PM, John C. Tull <jctull at gmail.com> wrote:
> Hi Barend,
> I found the 52 North website yesterday, but I could not figure out what the url was to get it to work in the plugin. Either that, or the plugin could not connect.
> Have you tried it yourself?
> Cheers,
> John
> On Nov 11, 2009, at 1:55 AM, Barend Köbben wrote:
>> There are some test WPS services available from WPS implementors:
>> The 52 north WPS, info at
>> http://52north.org/maven/project-sites/wps/52n-wps-site/demos.html
>> The sextante WPS library:
>> www.sextantegis.com/
>> Barend
>> On 11-11-09 08:25, "Düster Horst" <Horst.Duester at bd.so.ch> wrote:
>>> John,
>>> The access to a WPS ist the same like WMS or WFS.
>>>> Are there WPS implementations available online, or does one have to setup
>>>> their own server?
>>> In the next days I will set up a public WPS-Server but at the moment probably
>>> you need your own implementation.
>>> Horst
>>> Dr. Horst Düster
>>> Stv. Amtschef, GIS-Koordinator
>>> Kanton Solothurn
>>> Bau- und Justizdepartement
>>> Amt für Geoinformation
>>> SO!GIS Koordination
>>> Rötistrasse 4
>>> CH-4501 Solothurn
>>> Telefon ++41(0)32 627 25 32
>>> Telefax ++41(0)32 627 22 14
>>> mailto:horst.duester at bd.so.ch
>>> http://www.agi.so.ch
>>> ----- Originalnachricht -----
>>> Von: John C. Tull <jctull at gmail.com>
>>> Gesendet: Mit, 11.11.2009 00:53
>>> An: Düster Horst <Horst.Duester at bd.so.ch>
>>> Cc: qgis-user <qgis-user at lists.osgeo.org>
>>> Betreff: Re: [Qgis-user] QGIS WPS Client
>>> Horst,
>>> Can you provide some guidance on how to access a WPS? Are there WPS
>>> implementations available online, or does one have to setup their own
>>> server?
>>> Thanks,
>>> John
>>> On Nov 10, 2009, at 4:09 AM, Düster Horst wrote:
>>>> As the result from Vienna Hackfest I just published the new QGIS WPS
>>>> Client Plugin at the QGIS User-Contributed Python Plugin Repository.
>>>> The plugin is in an early stage and at the moment it has some
>>>> limitations.
>>>> 1. It works since trunk revision 12026 due to some changes of the
>>>> QgsVectorFileWriter Class
>>>> 2. It only work with complexData of type GML but you can process all
>>>> vectordata types loaded in QGIS canvas
>>>> 3. It doesn't work with complexData of type Binary like raster,
>>>> images or zip-Files (will coming soon)
>>>> The actual Version 0.33 is not considered stable yes. I hope on some
>>>> testing results from you.
>>>> Regards
>>>> Horst
>>>> Dr. Horst Düster
>>>> Kanton Solothurn
>>>> SO!GIS Koordination
>>>> Rötistrasse 4
>>>> CH-4501 Solothurn
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> International Institute for Geo-Information Science and Earth Observation (ITC)
>> Chamber of Commerce: 410 27 560
>> E-mail disclaimer
>> The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
