[Qgis-user] representing scale
Agustin Lobo alobolistas at gmail.com
Wed Nov 18 04:20:51 PST 2009
Have you tried View/Refresh or Ctrl+R after setting units
to m? I have not the problem you mention (on ~20 computers).
Agus
ambrish dhaka wrote:
> Dear all,
>                 I am working with SRTM data with lonlat and WGS84
> projection system. I wish to put up a scale that shows kilometres.
> Usually in ArcGIS you give units and there is automatic conversion. But,
> if I try to change the units on CRS window from degrees to metres the
> scale does not change and it shows the same degree distance labeling as
> metres, which is horrible.
> Urgent assistance needed.
> Thanks!
> Ambrish
> using qgis1.4 with grass plugins
> New Windows 7: Simplify what you do everyday. Find the right PC for you.
> <http://windows.microsoft.com/shop>
> Qgis-user mailing list
