[Qgis-user] georeferencer problem
Darren Cope
darrencope at gmail.com
Wed Nov 18 05:55:19 PST 2009
I'm also having problems with the Georeferencer plugin. I'm using QGIS 1.40.
r12167 installed via OSGeo4W on an XP box.
The only transform type that I can get to work is linear, which gives poor
results. I tried all of the others (polynomial, etc) and all of the
settings, and none of them work. When choosing (for example) Polynomial 1,
and clicking "Create" I get the warning about creating a GeoTiff. I click
"OK" and get the "Warp Options" dialog. At this point, the "OK" button and
"Cancel" button do nothing. I can set all of my options, but hitting "OK"
does nothing. Only the "X" to close the window does anything, and of course
this means I can't actually georeference an image! Any thoughts?
As well, I can't seem to find the Georeferencer Plugin in the repositories.
Any reason it's missing?
Cheers,
Darren Cope
Flavio Rigolon wrote:
>> Don't use Helmert, use the Polynomial option instead.
> Alex,
> Thanks! It works fine.
> flavio
> io uso Debian GNU/Linux
> user #413018 counter.li.org
> <<usiamo formati aperti!>>
> http://it.wikipedia.org/wiki/Formato_aperto
> Qgis-user mailing list
View this message in context: http://n2.nabble.com/georeferencer-problem-tp3479934p4025522.html
Sent from the qgis-user mailing list archive at Nabble.com.
