[Qgis-user] Support for (wrong) GEOCOVER projection	for	S	hemisphere in qgis
    Micha Silver
    micha at arava.co.il
    Wed Nov 18 22:20:10 PST 2009
Agustin Lobo wrote:
> No, what I was doing was different:
> I was setting the project to 18S (not 18N) with OTF reprojection, the
> raster to 18N
> and the vector layers got reprojected to 18S but the raster
> was not displayed.
Since QGIS doesn't deal with on-the-fly reprojection of rasters, we know
that you have to set the project CRS to whatever projection the raster
is in. In this case, since the Landsat are (wrongly) set to UTM N, I
guess you have to stay with that in order for vectors to be properly
registered.
Cheers,
Micha
> I was expecting the raster to be located in the S hemisphere because
> the coordinates are negative. In TNTmips, as the coordinates are
> negative, even if the raster CRS is set
> to 18N, the raster is displayed in the S hemisphere. Not sure if this
> is what qgis should do, though, as we are dealing with wrongly annotated
> raster layers: in UTM, S is S, not negative N.
> On the other hand, I assumed that if you set the project to 18N, then
> the vector layers would projected to the N hemisphere.
> But have tried defining the project as 18N as you say, used Coordinate
> capture to check lon,lat, and actually get correct lon,lat coordinates
> (in the S
> hemisphere). The vector layers are reprojected to
> 18, no matter the S or N, the original latitude correctly defines the
> hemisphere.
> So it works "your way", thanks!
> Agus
> Micha Silver wrote:
>> Hi Agus:
>> I am actually able to do just that. I also am using some Landsat
>> GEOCover images from below the equator, projected, as you say in UTM
>> 39_N_.
>> I load the raster, set the project CRS to that (UTM Northern)
>> projection, and enable OTF projection. Then I can overlay vector
>> layers, which are WGS84 Lon-Lat., and they are correctly located.
>> It's usually not very helpful to say "works for me" but...
>> Anyway, HTH,
>> Micha
>> Agustin Lobo wrote:
>>> The global set of Landsat images on GEOCOVER
>>> https://zulu.ssc.nasa.gov/mrsid/mrsid.pl
>>> is on UTM/WGS projection
>>> but with the Southern hemisphere tiles as UTM zones in the N with
>>> negative coordinates. For example, a tile that should be at 18S is
>>> actually 18N with negative coordinates
>>> ("Non-standard UTM definition: For the southern hemisphere, the
>>> GeoTiff files
>>>   contain positive zone numbers with negative northing coordinates")
>>> https://zulu.ssc.nasa.gov/mrsid/docs/GeoCover_circa_2000_Product_Description.pdf
>>> As we have some vector layers on geographic coordinates WGS84 and a
>>> Geocover tile for 18S,
>>> I've set the project as 18S, enabled CRS reprojection on the fly,
>>> and set
>>> the raster CRS to 18N. Unfortunately, QGIS does not display the
>>> raster, even
>>> selecting zoom to layer extent. (Using Mimas).
>>> This is probably not a problem of QGIS, the Geocover projection is
>>> just wrong,
>>> but would like to know if there could be a way to circumvent this
>>> problem to
>>> be able to use GEOCOVER tiles of the S hemisphere within QGIS.
>>> A way could be making a world file with the Georeferencer plugin,
>>> but perhaps
>>> there is a more general way.
>>> Thanks
>>> Agus
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> This mail was received via Mail-SeCure System.
