[Qgis-user] calculating area
Nik Go nikolai.go at gmail.com
Fri Nov 20 00:04:17 PST 2009
Hello. I'm trying to calculate area of my shapefiles but I'm not really sure
if I'm doing it right.  I expect results to be in meters (sq meters or sq.
kilometers) but read out is in sq. degrees.  I'm told that I have shapefiles
in geographic coordinate system WGS 84 but I don't know to convert this to a
projected coordinate system from qgis.
So, how should I go about doing
   - converting from geographic coordinated to projected coordinates so I
   could
      - determine/calculate area
      - determine distance between points
   - convert sq. degrees to sq. meters?
Thanks
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091120/ca7f7513/attachment.html>
