[Qgis-user] Labelling
Martin Dobias wonder.sk at gmail.com
Fri Nov 20 04:44:31 PST 2009
Hi Piotr
On Thu, Nov 19, 2009 at 4:40 PM, Piotr Pachół
<piotr.pachol at wodgik.katowice.pl> wrote:
> Hello,
> I've just had for the first time possibility to see how labelling plugin
> works (Qgis 1.4 r.12167).
> Martin - I must say it was fantastic job.
> Nevertheless I would like to add some sugestions:
> 1. Labels without line objects - when we have a line layer with
> classificated symbology
> and we delete some classes we still can see labels for line objects from
> deleted class value.
Thanks for pointing out, that should be fixed in r12206.
> 2. Labelling points with angle defined in one of fields – it is partially
> made because we can't change:
> a) angle units (degrees, grads, radians),
> b) angle rotation style:
> - geographic (zero north, clockwise direction) which is necessary for me,
> - arithmetic (zero east, anticlockwise direction) which is used in Qgis,
> May be defining angle units in whole project of Qgis is necessary?
I think it's sufficient to use only degrees within user interface as
it's most common unit (ok, some might want use grads). But for
data-driven rotation of labels it could be considered to give the user
chance to set both units type and rotation style.
> 3. What about conflict detection between labels on different layers?
The conflict resolution is done for all layers at once. In the
labeling settings dialog you can also set priority for each layer.
Regards
Martin
