[Qgis-user] Attribute Actions
Kumaran Narayanaswamy kumaran.narayanaswamy at kcubeconsulting.com
Sun Nov 22 17:24:17 PST 2009
Hello,
I am having trouble making the Attribute Actions work in 1.0.2 Kore and
1.3.0 Mimas in Windows XP. Can anyone tell me what is wrong?
Steps Followed
1.       Added a Shape file containing buildings
2.       Right Click building layer and open properties and clicked Action
tab
3.       Action Property Name = Google Search Action = firefox
http://google.com/search?q=
4.       Selected the field BUILD and clicked Insert field. Now Actions
String is firefox http://google.com/search?q=%BUILD
<http://google.com/search?q=%25BUILD>
5.       Checked Capture Output
6.       Clicked Insert Action.Clicked Apply and Ok
7.       Using the Identify tool clicked on a feature
8.       In the Identify feature results window right clicked and selected
the action Google Search
9.       Unable to run command firefox http://google.com/search?q=marina
10.   I ran the firefox http://google.com/search?q=INDIA command from my run
prompt and I was able to open the browser.
Can any one let me know what I am missing to invoke firefox from QGIS
environment? Thanks.
Regards
Kumaran
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of JD Comtois
Sent: Monday, November 23, 2009 6:14 AM
To: Richard Duivenvoorde
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] attribute actions oddities in 1.3.0?
Hi Richard.  thanks for your interest.
I have only the filename (not the full path) as the attribute value.  In the
action definition, I used %% and not %view1.  using this approach in
1.0.1KORE i was able to simply right click on any of the attribute values
and run the action and that attribute value would be sent to the destination
application (in this case VLC media player).
In 1.0.1 the action had to have the full path to the application in one set
of quotes, and then a space and then in a separate set of quotes, I would
put the path to the file to be viewed but in place of the actual filename, I
put %%.  this is supposed to allow the value of the selected attribute to be
sent to the application.
thus, i had the action defined as:
"c:\program files\vlc\vlc.exe" "c:\pics_n_vids\%%"
So that when I right clicked on the value of a given attribute, that value
would replace the %% and the video or picture would play.
could you try that and see what happens?
thanks!
jd
On Sun, Nov 22, 2009 at 4:44 PM, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
Richard Duivenvoorde wrote:
<attributeactions>
<actionsetting action="C:/programs/IrfanView/i_view32.exe
c:\temp\issues\actionAttribute\%%" capture="0" name="task4" />
<actionsetting action="C:/programs/IrfanView/i_view32.exe <actionsetting
action=""C:/programs/IrfanView/i_view32.exe"
"c:\temp\issues\actionAttribute\%view1"" capture="0" name="task6"
</attributeactions>
task4 was not working (but seemed to be an example from you email? So I
tried that also ... ).
mmm, wrong copy pasta ...
<attributeactions>
c:\temp\issues\actionAttribute\%view1" capture="0" name="task5" />
<actionsetting action=""C:/programs/IrfanView/i_view32.exe"
</attributeactions>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091123/5c528c18/attachment.html>
