[Qgis-user] ECW imagery in Southern Hemisphere
Agustin Lobo
alobolistas at gmail.com
Thu Nov 26 06:12:03 PST 2009
Can you use gdalinfo (eventually gdalinfo -nomd ) and display the
geographic information? You probably can see the problem there
and use something similar to what was suggested by Roland Hill to
write an standard projection information:
gdalwarp -t_srs '+proj=utm +zone=34 +south +datum=WGS84' -srcnodata 0
-dstnodata 0 -multi -of GTiff -co COMPRESS=LZW -co TFW=true -co
INTERLEAVE=BAND $1 Z34S_$1
(see the thread here:
http://n2.nabble.com/forum/PostLink.jtp?post=4030315 )
Agus
Micha Silver wrote:
> I need to assist some agricultural projects using QGIS, and located in
> the Southern Hemisphere. They have a large set of ECW imagery which
> displays "up side down". It looks as if the images are rotated around
> their northern edge. The northern edge is at the bottom of the map, and
> the southern edge at the top. Hope I've explained myself...
> The imagery has no CRS in the metadata data but they are located in
> UTM40S. The same images in Arcview display correctly...
> Any ideas how to overcome this would be greatly appreciated.
> Thanks,
> Micha
> Qgis-user mailing list
